VPN between ZyWall 110 and USG 20 is CONNECTED but can't ping
ictforever
ictforever Posts: 15 image  Freshman Member
edited April 2021 in Security
Hi great people,
I have a VPN IPSEC between two beautiful Zyxel firewalls. I have a connection, so that is great! The only problem is, I can't ping to each other. I checked everything but I can't find the issue. Anyone here that can guide me to the right direction or can help me through TeamViewer?
Thanks a lot!
Regards
  • lalaland
    lalaland Posts: 91 image  Ally Member
    First Answer First Comment Friend Collector Sixth Anniversary
    Do you mean you cannot ping to Device(Peer USG interface IP) or Remote site lan side host?
  • ictforever
    I can't ping to the remote site lan. For example the firewall on the remote site or the printer.
  • Zyxel_Cooldia
    It looks like the packet is blocked by security policy rule, can you disable both site firewall rule temporarily for testing and try it again?
  • ictforever
    edited June 2018
    The problem was that there was an inactive vpn gateway on the top. After removing it, it worked.
    It's weird, because it was showing inactive. I thought that this will not apply on the rules.
    Zyxel Support helped me on this. Thanks to them!
