SFP+ Transceivers Compatibility
BallcoIt
BallcoIt Posts: 6 image  Freshman Member
edited August 2022 in Switch
What Transceivers are compatible with the XGS2210 model switches?
Is SFP+ a standard protocol and are all Transceiver Brands interchangeable?
  • Zyxel_Ryan
    Zyxel_Ryan Posts: 72 image  Zyxel Employee
    First Answer First Comment Friend Collector
    Hi @BallcoIt
    Only certain models of transceiver are guaranteed its compatibility, but not all Brands because there are numerous SFP in the market. It is impossible to verify all of them.
    For details, you can refer to datasheet of XGS2210 as attachment.
    Ryan
  • BurchSung
    BurchSung Posts: 1 image  Freshman Member
    Hi...I was working with a stack of Dell PowerConnect 6248P switches. One switch had the dual SFP+ 10Gbps module installed in the back. Since the SFP ports on the front are shared with copper ports, I was hoping to install a 1G SX SFP in the SFP+ module. No dice. It would not recognize the SFP. Install the SFP into one of the front ports and it worked fine.
    printed circuit board assembly
  • CrazyTacos
    CrazyTacos Posts: 53 image  Ally Member
    First Answer First Comment Friend Collector Sixth Anniversary
    @BurchSung
    You mean you connected a 1G SFP on a 10G port?
    Did you remember to change the port speed/duplex to 1000Mb full?
