New Users added to Objects after firmware update
Yay one of my ideas come true
Change the port for SSL VPN — Zyxel Community
You can make the WWW more secure from logins from WAN if you add a allow for LAN1 then a block all zones.
Hi @inchica
You can display login portal page when connection is initial from Internet but deny admin account to login from WAN side even password is correct.
(Configuration > System > WWW)
Or you can deny HTTPS traffic from WAN to ZyWALL, then login portal will unable to display on browser.
(Configuration> Security Policy > Policy Control)
@splayer7 I checked our firewall logs, and noticed warnings:
I import the logs into Excel to keep a baseline for the firewalls. WAN has been disabled for admin. I have our logs setup to alert us of all attempts to access the firewall (actual users and bad actors). I hope that helps!1
- 237 Nebula Ideas
- 6.8K Security
- 745 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
