L2tp error wen user changing domain password
ZCNE Certified
Thanks.
What is your topology?
What is the model and firmware version?
Could you share the screenshot of the error log?
Below are the reference guide to set up login with domain namehttps://community.zyxel.com/en/discussion/4105/ad-auth-with-built-in-windows-l2tp-client
I guess the reason is because Windows client password did not sync new password to your ActiveDdirectory Server, so caused password mismatch.How about sync your ActiveDdirectory user database with Windows client before build L2TP tunnel?
As your description you should already found the reason. lol0 -
Thanks for the reply.With the problem of vulnerability I have not had time to review the forum JAJAJAJA.I am going to try this option which had never worked for me.It happens to me with different devices. VPN, ATP, USG .....I keep you informed.0 -
Its Working!!!! Thanks Jerry!!!!Zyxel_Jerry said:What is your topology?
- 441 Beta Program
- 533 USG FLEX H Series
- 334 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 461 News and Release
