New Users added to Objects after firmware update
2»
    PeterUK Posts: 4,707 image  Guru Member
    Yay one of my ideas come true
    Change the port for SSL VPN — Zyxel Community
    You can make the WWW more secure from logins from WAN if you add a allow for LAN1 then a block all zones.
  • Zyxel_Stanley
    Zyxel_Stanley Posts: 1,482 image  Zyxel Employee
    edited June 2021
    Hi @inchica
    You can display login portal page when connection is initial from Internet but deny admin account to login from WAN side even password is correct.
    (Configuration > System > WWW)
    Or you can deny HTTPS traffic from WAN to ZyWALL, then login portal will unable to display on browser.
    (Configuration> Security Policy > Policy Control)
  • inchica
    inchica Posts: 10 image  Freshman Member
    @splayer7 I checked our firewall logs, and noticed warnings:
    I import the logs into Excel to keep a baseline for the firewalls.  WAN has been disabled for admin.  I have our logs setup to alert us of all attempts to access the firewall (actual users and bad actors).  I hope that helps!
