Zyxel USG60 Syslog-over-TCP+TLS (TCP 6514)
Hi @TheDoctor
So far, we support UDP 514 port for the syslog server. If you need the encrypt funtion for the logs, we suggest to use SecuReporter which is using https protocol with port 443 to transmit the log data to the SecuReporter server.
Joslyn0 -
Hi @dpipro
We can download the history logs from SecuReporter. The file will be compressed every day.
Here is our license spec. If you are the normal user, the history logs will be save for 7 days. If you are the premium user, the history logs will be saved for 1 year.
https://www.zyxel.com/tw/zh/products_services/Security-Service-Cloud-CNM-SecuReporter/license-and-spec
Joslyn
- 588 USG FLEX H Series
- 476 News and Release
ZCNE Certified
