Guest SSID Disappears when I enable NAT
On which device?Do you use vLANs?0
Hi @NeillMcG,NAT mode non-supported models disable any SSID with NAT mode enabled, so please check if your model is supported NAT mode.The supported list can be checked on the NAT mode option as below screenshot.
- 220 Nebula Ideas
- 602 USG FLEX H Series
- 480 News and Release
