Guest SSID Disappears when I enable NAT
NeillMcG
NeillMcG Posts: 1
edited May 2024 in Wireless
hI,
I wish to configure a guest SSID with no password and NAT enabled so my network in protected. However every time I enable NAT the SSID disappears. Can someone please help?
  • mMontana
    mMontana Posts: 1,440 image  Guru Member
    On which device?
    Do you use vLANs?
  • Zyxel_Freda
    Zyxel_Freda Posts: 397 image  Zyxel Employee
    25 Answers First Comment Friend Collector Third Anniversary
    Hi @NeillMcG,
    NAT mode non-supported models disable any SSID with NAT mode enabled, so please check if your model is supported NAT mode.
    The supported list can be checked on the NAT mode option as below screenshot.
