Instabilities with GS1200-8 managed
2»
  • Zyxel_Adam
    Zyxel_Adam Posts: 429 image  Zyxel Employee
    Zyxel Certified Network Administrator - Nebula 25 Answers First Comment Friend Collector
    @ODuis
    May we know the result of your test?
    Does flow control and port based QoS affect the link speed between your ISP router and GS1200?
    Adam
  • ODuis
    ODuis Posts: 8 image  Freshman Member
    Thanks for asking, Adam.
    Yes, switching off both Flow Control and port based QoS made it rock stable. I could try to switch on Flow Control since by itself it did not seem to make the difference, but I don't dare touching it since it works so nicely now. Since the gigabit switch has enough headroom for the 100mbit internet connection I would probably not see much difference fine tuning those two features anyway.
  • Zyxel_Adam
    @ODuis
    Much appreciate for your answer and testing.
    Since we couldn't duplicate the issue on our site, we will note that Flow Control and Port based QoS may have link speed issue with specific ISP modem.
    Thanks again for all your efforts.
    Adam
  • ODuis
    Like outlined above, the flanky speed issue with the router was just one. Also problematic were the seemingly sporadically dead ports on the other devices. But anyway, solved with these settings.
