How to route outbound IP USG100.
I managed to configure a Virtual IP on a WAN Port for incoming connections.
xxx.xxx.xxx.100 -> 192.168.10.10 (machine01)
xxx.xxx.xxx.101 -> 192.168.10.11 (machine02)
The problem is, that the outbound IP for the machines are the same (xxx.xxx.xxx.100) and I need machine01 outbound at 100 and machine02 outbound on 101.
How can I achieve that?
Thanks for your help!
Dan
Dan
Make a routing rule with:
incoming = Interface
member = lan1 or where 192.168.10.11 is
source address = 192.168.10.11
Source network address translation = xxx.xxx.xxx.101
Thank you!0
Hi @Dani2323
Policy Route rules are able to fulfill your requirement.
You can create IP objects for your machines and public IP addresses first.
And configure then with correct rule and enable Address Translation(SNAT) setting.
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
