USG210 Issue with displaying to long user name
Wojtas
Wojtas image  Freshman Member
Here is the screen where you can see how user names are displaying for users with too long username:
I can't logout those users, and for every new connection new session is create. Is it normal behavior?
  • Zyxel_Stanley
    Zyxel_Stanley image  Zyxel Employee
    edited July 2021 Answer ✓
    Hi @Wojtas
    We have addressed symptom and it will fix in next forum release.
  • Zyxel_Stanley
    Hi @Wojtas
    Which version is working on your device?
    I tested in 4.65 version, and IKEv2 VPN client could display correctly and could force logout by admin-type account success.
    You may try to upgrade firmware and flush browser cache first and make sure if it could help your symptom.
  • Wojtas
    edited July 2021
    Hi @Zyxel_Stanley
    I working on vr. 4.63 but I will upgrade it during the weekend. Could you make a test with the username with more then 34 length, and more then 21 signs before "@" eg.: testusername.testusersurname@usg.com ? Thank you!
  • Zyxel_Stanley
    Hi @Wojtas
  • Wojtas
    Hi @Zyxel_Stanley
    I have updated my USG from 4.65(AAPI.0) to vr. 4.65(AAPI.1) but the issue still occurs. In which version will you fix it?
  • Zyxel_Stanley
    Hi @Wojtas
    It will fix in next FCS firmware and release schedule will at Q4.
