How to use ATP200 for my studio network
Not exactly like that but... yes. That's possibleTwo networks on the LAN side and two WAN connections.0
Hi @Manson,
It is okay to set two wan connections.
However, the IP address of two wan connections should not be in the same subnet.
In the topology, it seems you'd like to access each internal server via different IP addresses.
You can follow the guide to configure NAT rules.
https://community.zyxel.com/en/discussion/11120/how-to-set-a-range-of-ip-addresses-on-usg-interface
- 603 USG FLEX H Series
- 480 News and Release
