IKE Log.. every 30 sec
Hi everybody,
after few days studying VPN configuration guides, I created (with satisfaction because it's my first) a stable and perfectly working tunnel between 2 locations (USG60W, v.4.31(AAKZ.0) <-> TL-ER6120).
After that, however I found an overrun of logs due to IKE
I have not enabled any connection check in any of the 2 firewalls involved..
It's normal or there's some policy (or other settings) that I should correct?
Hi @Skylink, it's usual because you have IKE logging and possibly others enabled by default in the System Logging settings.
If you dont want these logs , simply click on the radio button in USG web UI / Configuration / Log & Report / Log Settings / Log Category Settings / System Log / Disable.
We keep all logs by routing them to FreeBSD and MacOS servers for audit purposes...
See the attachment ...
Oh by the way Attn! Zyxel_kidz... 一个容易的错误 , you guys have mis-spelt the English in these columns as "diasble" instead of "disable"
HTH
Warwick
Hong Kong2 -
Hi Zyxel_Cooldia ... good boys! .....0
- 3K Nebula
- 229 Nebula Ideas
- 130 Nebula Status and Incidents
- 6.6K Security
- 661 USG FLEX H Series
- 359 Security Ideas
- 86 Switch Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 305 Service & License
- 497 News and Release
- 95 Security Advisories
- 5K FAQ
- 89 About Community
- 110 Security Highlight
