NAT - Secondary RDP Port - AzureAD vs Local logins
JeremyHowes
in Security
Using USG210-4.65(AAPI.0)
Trying to configure NAT for a secondary RDP connection port. Having issues connection to a AZUREAD account and not local account. Internal LAN RDP works just fine on with both a local and AZUREAD accounts. But I can't get both to work through NAT. The local account will connect and login in. The AZUREAD account will connect but login fails. Any Ideas?
Do you authenticated account by LDAPs? Zyxel device doesn't support SAML( Azure AD) but support LDAPs(Azure AD DS), so that need to use Azure AD DS integrate with Azure AD.
I am not sure do you mean you NAT to internal Server with RDP service, and login fail if authenticated by AZUREAD account?
The "Local account" do you mean it's from local AD?
Regarding to Azure AD, you can reference this example
https://community.zyxel.com/en/discussion/10030/use-azure-active-directory-to-authenicated-vpn-access
Thanks Jeremy for the feedback. We only use AzureAD as we have no local servers. When I say local user, its the local account on the PC we are try to connect to. I upgraded to 4.65, because the security advisory from Zyxel.0
@JeremyHowes
Can you collect the packet on wan, and Lan which PC located, and set AD's IP as Host IP during reproducing issue then private message the packet to me for investigation.
EX:
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
