Zywall USG310 X-XSS-Protection HTTP Header missing on port 443.
GrahamWebb
in Security
Hi our office Zywall has failed a PCI scan due to the following X-XSS-Protection HTTP Header missing on port 443.
Is there a command that can be run on the Zywall to enable this we are on V4.64(AAPJ.0) firmware.
Kind regards
Graham
Hi @GrahamWebb
Tried the same CLI from web cli and didn't see the same symptom. Can you find a not so busy hour and try it again (please have console connect to the device). If this symptom always exist, please send the console dumped to us in private message.
Hi Sorry I think you are getting mixed up with my other post regarding the x-frame-header header I have fixed that vulnarability now but the PCI scan is now failing on the x-xss-protection header being missing. Is there a similar command I can run to enable this header?
Hi @GrahamWebb
Sorry for mixing your posts. Currently the x-xss-protection header is not supported by Zywall/USG/ATP/FLEX series. We will put this feature into our evaluation queue and put this request into the ideas category as well. Thanks for your feedback about it.0
- 602 USG FLEX H Series
- 480 News and Release
