Impossible to remove EZMODE_VPN_L2TP
@danieles
The EZMODE_VPN_L2TP rule can be deleted with following way.
Go to Expert Mode>Configuration>VPN>IPSec VPN>VPN Connection>Select EZMODE_VPN_L2TP then Click the Remove button>Press Yes.
sure, I have tried several times to remove it but IT DOESN'T WORK! After click the configuration is still present.
@danieles
I checked it again with firmware: 4.39(ABAQ.0) without any issue.
What firmware version are you using? Use Incognito window and check it again.
If the issue still occur, can you private message the configuration for check further.0 -
hello i have the same issue. Created a VON rule in easy mode, and evene if i go to expert and delete i get error Latest firmware on router is USG20W-VPN0
Triple check object references.
@stefanocps
I checked it locally again, the tunnel which created in easy mode still can be deleted.
Can you private message your configuration for check further?
- 441 Beta Program
- 210 Nebula Ideas
- 539 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 464 News and Release
