VLAN for Wifi ATP700 & WAX510D
Antares3000
in Security
I've a cabled network with 3 VLAN on ATP700:
- Main network on VLAN 1
- Tech network on VLAN 2
- Guest network on VLAN 3
I need to configure:
- WiFi connected on Main network on VLAN 1
- WiFi connected on Tech network on VLAN 2
- WiFi connected on Guest network on VLAN 3
I use ATP700 Wifi controller and 3 different managed switch. Switch 1 manage VLAN1, switch 2 manage VLAN2 and switch 3 manage VLAN 3.
So:
1 - where have i got to phisically connect WAX510D cable ?
2 - how can i configure the different VLAN to let user connect to the right network?
Regards
BC
So:
Regards
BC
I didn't use bridge mode and vlan. I used tunnel and i connected the 3 SSID to the different port of the different network. For now it works.0
Hi @Antares3000
You can follow this setting for your requirement.
Internet------ATP700(LAN1+VLANs)------(P1)Switch(P2)-------AP
(1) On ATP700, you can configure multiple VLANs and bind on LAN interface first.
Configuration > Network > Interface > VLAN
e.g. VLAN11, VLAN12, VLAN13
(2) Configure VLANs setting on your switch. P1 and P2 port with tagging out.
(3) Create AP SSID profiles for Main/Tech/ Guest network and with different VLAN ID.
Configuration > Object > AP Profile > SSID
(4) Add SSID profiles into "default" AP group setting.
Configuration > Wireless > AP Management > AP Group
(5) Connect your AP to switch, it will get IP address from ATP700 LAN interface.
Go to Monitor > Wireless > AP Information.
It will display AP those discovered in this table. Click "" button to add AP into managed AP list.
After adding AP into list, it will start to upgrade AP firmware and apply AP configuration.
Once it finished, client will able to find SSID when scanning WIFi signal.0 -
Point 1,3,4,5 are ok...we understood. Cannot understand exactly what you mean in point 2. Can explain better how to configure switch? Thks0
Hi @Antares3000
Here is Zyxel Switch setting: Create Static VLAN ID for your requirement. Fixed VLAN ID on the physical port and with tagging out when outputting the traffic.
- 439 Beta Program
- 191 Nebula Ideas
- 6.2K Security
- 468 USG FLEX H Series
- 308 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 440 News and Release
- 4.3K FAQ
- 93 Security Highlight
