Zywall USG310 X-XSS-Protection HTTP Header missing on port 443.
GrahamWebb
GrahamWebb Posts: 27 image  Freshman Member
Hi our office Zywall has failed a PCI scan due to the following X-XSS-Protection HTTP Header missing on port 443.
Is there a command that can be run on the Zywall to enable this we are on V4.64(AAPJ.0) firmware.
Kind regards
Graham
  • Zyxel_Vic
    Zyxel_Vic Posts: 323 image  Zyxel Employee
    25 Answers First Comment Friend Collector Eighth Anniversary
    Hi @GrahamWebb
    Tried the same CLI from web cli and didn't see the same symptom. Can you find a not so busy hour and try it again (please have console connect to the device). If this symptom always exist, please send the console dumped to us in private message.
  • GrahamWebb
    Hi Sorry I think you are getting mixed up with my other post regarding the x-frame-header header I have fixed that vulnarability now but the PCI scan is now failing on the x-xss-protection header being missing.  Is there a similar command I can run to enable this header?
  • Zyxel_Vic
    Hi @GrahamWebb
    Sorry for mixing your posts. Currently the x-xss-protection header is not supported by Zywall/USG/ATP/FLEX series. We will put this feature into our evaluation queue and put this request into the ideas category as well. Thanks for your feedback about it.
