IPsec VPN connection, Windows RDP keep dropping
UFS
UFS Posts: 1
I have IPsec VPN connection between main office and branch. I have computers(XP, Win7,Win10) at main office. Users at branch will use windows RDP connect to computers at Main office.
The RDP session Intermittent drop.
How to resolve this issue?
Both sites use Flex 500 firewall.
  • Zyxel_Cooldia
    Zyxel_Cooldia Posts: 1,537  Zyxel Employee
    Hi @UFS,
    Welcome to Zyxel community.  =)
    Can you send me both site configuration file in PM for further checking?
  • Hi @Zyxel_Cooldia   I have the same issue.
    I have IPsec VPN connection between main office and branch. I have computers on windows 10 at main office. Users at branch will use windows RDP connect to computers at Main office.
    How to resolve this issue please ?
    Both sites use usg60.
    Thanks a lot.
  • mMontana
    mMontana Posts: 1,432  Guru Member
    It's used only for RDP? Or it's steadily working for other tasks/transfers?
    During RDP Session, could you log if the tunnel is still built and/or capable of transfer?
    Did you setup correctly the ingress and egress capabilities of your WAN connections on both side?
    Did you created any BMW rule for keeping the RDP slowly but steadily working?
    PeterUK Posts: 3,891  Guru Member
    Seeing the same problem with VPN300 V5.10(ABFC.0) by 4G to Zywall 110 V4.70(AAAA.0)ITS-WK46-r102519 by cable site to site tunnel. The problem can take 10-20mins and the tunnel does not seem to drop going by the logs and uptime.
    I set the PC1 to ping the remote PC and RDP to it with a ping to 8.8.8.8
    I have another PC2 also ping the remote PC
    When the RDP drop happens PC1 and PC2 ping drop but the ping to 8.8.8.8 is fine
    Might do a local site to site for testing.
  • It's used only for RDP? Or it's steadily working for other tasks/transfers?
    Both
    Yes
    Yes
    I don't know how to do this.
    I read this
    "There was a setting in the Firewall that would "flush states for a gateway that goes down". That was the default setting. Checking the tick box "overrides this setting by not clearing states for existing connections." Checking that box prevented the disconnects. I was able to RDP for over an hour and no disconnects."
    But i dont know where it is on zyxel
    Do you know if your tunnel is by protocol 50 or UDP 4500? doing a local site to site with protocol 50 shows it to be stable with RDP I think the problem might have to do with NAT-T
  • Zyxel_Cooldia
    Hi @Mad_cha,
    Please hit CLI Router# debug system no-udp-disperse active and test if it is stable in RDP connection.
    edited December 2021
    Hi @Mad_cha,
    Did that both ends RDP still drops out
    It definitely has to do with NAT-T UDP 4500 I did a local test with three routers so that the tunnel uses NAT-T UDP 4500 and RDP dropped the problem does not happen if the end points use protocol 50 WAN IP to WAN IP.
    How I tested
    VPN300
    PC 192.168.255.51 to 192.168.138.2 RDP PC and ping
    ge5 192.168.255.49/28
    ge4 external
    IP 192.168.2.2/24 gateway 192.168.2.2
    site to site IP 192.168.4.1
    ge4 to VPN2S LAN2
    VPN2S
    LAN2
    IP192.168.2.1/24
    WAN2 port 4 NAT
    IP 192.168.4.2/24 gateway 192.168.4.1
    Port4 to Zywall 110 WAN2
    Zywall 110
    WAN2
    IP 192.168.4.1/24
    site to site with Dynamic Peer
    LAN2 192.168.138.1/28
