Reboot of VPN300 with group WILDCARD FQDN (Videos) not applying for BWM.
Hi @PeterUK
I will send private message to you for further check in this case.0
Hi @PeterUK
The Wildcard FQDN will cache DNS query those pass through by ZyWALL, and save it in system cache.
Before Wildcard FQDN up to date IP address, it is unable to apply BWM setting in system.
You can have a check if IP list has renewed in cache list after reboot. (Monitor > system status > FQDN Object)
Or try to flush DNS cache on your PC and re-connect video again.
Thats not the problem I have to BWM rule above then reboot the VPN300 when booted go to watch a 4K video with bittorrent running DNS is done the IP of the steam is listed in Monitor > system status > FQDN Object but the BWM rule is not applying. That why I have to do the workaround as above.
Hi @PeterUK
Can you left only WILDCARD FQDN object in BMW rule, and double confirm if there is log entry after rebooting the device?
Not sure what your asking me to do?
I do see on a reboot with the group FQDN
The BWM rule 2 will not take effect, due to /destination/ group object are empty.
Which is normal because DNS has not happened
I did some more tests with rebooting with a group Destination FQDN for BWM and there is a problem. I then used a single FQDN not in a group *googlevideo.com and rebooted and the BWM rule worked fine so the problem is if you do a group of FQDN for BWM on a reboot.
Hi @PeterUK
I will send private message to you for further check in this case.0 -
This issue is because BWM function did not renew IP address automatically, so caused BWM rule did not work. It will fix in FCS firmware in the future.0
Broken again in VPN300_5.30(ABFC.0)0
Fix inV5.30(ABFC.0)ITS-22WK16-2022-05-19-2204013210
Hi @PeterUK
It's good know the new firmware resolved the symptom.The issue is a side effect from the other fix.
So it caused wildcard FQDN doesn't work in BWM rule. Whatever, the solution will fixed in next formal release.
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 492 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 47 Wireless Ideas
- 285 Service & License
- 455 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
https://www.youtube.com/watch?v=G1hKzCkywM8&t=486s
