USG60W – Report of logged in user(s)
Hi @Ikarus
Once license expired, then USG will stop send logs to SecuReporter server.
The logs live time on SeuReporter server is 30 days. System will auto delete entries those arrived to server over 30 days.
For SecuReport Login portal. Web page will unable display your device which license has expired.
But you still can renew your license after receiving a renewal notification before either expires.
Hi @Ikarus
The log entry is not unlimited. It will flush the oldest entry when it is full.
You can check concurrent logged in user list by: Monitor > System Status > Login Users.
Or you can consider send out all of system log to external syslog or SecuReporter server.
Then you can view all of syslog those saved on external server.0 -
Hi @Zyxel_Stanley,
Many thanks for the answer.The only thing regarding SecuReporter:
- Is it free to use? I see a license expiration date.
What will happen after that date?
Thanks,
Ikarus
Hi @Ikarus
- 439 Beta Program
- 191 Nebula Ideas
- 6.2K Security
- 468 USG FLEX H Series
- 308 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 441 News and Release
- 4.3K FAQ
- 93 Security Highlight
