USG60W – Report of logged in user(s)
Ikarus
Ikarus Posts: 20 image  Freshman Member
I‘m using a USG60W and I want the see the logged in user(s) via “Monitor – Log – View Log – Cat (User)”
If use that route I see nothing.
Is there a way to get a report of the logged in users?
Ikarus
  • Zyxel_Stanley
    Hi @Ikarus
    Once license expired, then USG will stop send logs to SecuReporter server.
    The logs live time on SeuReporter server is 30 days. System will auto delete entries those arrived to server over 30 days.
    For SecuReport Login portal. Web page will unable display your device which license has expired.
    But you still can renew your license after receiving a renewal notification before either expires.
  • Zyxel_Stanley
    Hi @Ikarus
    The log entry is not unlimited. It will flush the oldest entry when it is full.
    You can check concurrent logged in user list by: Monitor > System Status > Login Users.
    Or you can consider send out all of system log to external syslog or SecuReporter server.
    Then you can view all of syslog those saved on external server.
  • Ikarus
    Hi @Zyxel_Stanley,
    Many thanks for the answer.
    The only thing regarding SecuReporter:
    • Is it free to use? I see a license expiration date.
    What will happen after that date?
    Thanks,
    Ikarus
  • Zyxel_Stanley
    Hi @Ikarus
