Select Which Websites Go Through VPN
I have USG flex 200 and I am wondering if it is possible to setup VPN on it and use this VPN only for specific web site.
Similar problem for some other products is described here:
https://blog.flashrouters.com/2016/09/01/setup-vpn-on-router-vpn-for-specific-websites/
Yes this is possible.You would create an FQDN address object for the specific website which you can then use in a policy route rule to tell the router use VPN tunnel for that website.Example policy route rule:Incoming: anySource: anyDestination: [FQDN_address_object]Next-Hop: [VPN_Tunnel]1
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
