Problem with VLAN on ZYXEL AP NWA210 and multiple SSIDs
who can help us? We have a problem with a new Zyxel WLAN AP NWA210AX.
We need to config it in standalone mode.
Firmware: V6.20(ABTD.0)
We want to use two SSIDs for example
SSID1 VLAN 1 WPA3 1111111111
SSID2 VLAN 11 WPA2 2222222222
The AP ist connected by cable to a firewall Sonicwall TZ270.
LAN packets from the firewall for SSID1 are untagged.
LAN packets from the firewall for SSID2 are tagged with VLAN 11.
The function oft he firewall was testet with a PC.
We unplugged the cable from the AP an plugged it to the test PC.
Depending oft he VLAN tag oft he PC network card the PC gets an IP from the correct subnet by DHCP.
If we plug the cable out oft he PC into the AP we have the following problems:
WLAN client connected to SSID1
client gets an IP by DHCP from the VLAN 1
all works fine
WLAN client connected to SSID2
client gets no IP by DHCP from the VLAN 11
no connection
manual setting of a possible IP from the correct subnet does not help
no connection
WLAN client connected to SSID2 we can see in the firewall protocol no packets tagged with VLAN 11
and we cannot find the MAC oft he WLAN client in the protocol.
LOG of the firewall while testing with an PC on the LAN-cable. The ethernet card of the PC is tagged with VLAN 11.
LOG of the firewall while testing with the AP and a WLAN
No LOG entrys while testing with the AP and a WLAN
In the web interface of the AP we can see the WLAN client connected to SSDI2
Connected to SSID2 the WLAN client sends an ARP call without any answer.
After timeout the WLAN client uses the IP 169.254.65.55
This IP we can see in the web interface oft he AP.
Who can find the mistake?
Screenshots of the AP:
Best Answers
From the screenshot you provided, the configuration on SSID is correct - the AP should forward the clients packet out with the correct VLAN tag.
Please first make sure the Ethernet cable is connect to AP's [UPLINK] port (Not the LAN port), if the issue still occurs, please help us to collect the diagnostic info on the GUI, and send it to me through the private message.
GUI Directory for collecting the Diagnostic Info:
Best Regards,
Richard0 -
After double check the screenshot you provided, found one thing strange: The Ethernet client configured in VLAN11 (192.168.2.51) got the IP address in the same subnet as the wireless client connected to SSID1 which is in VLAN1(192.168.2.76).
So please make sure your gateway setting is correct and able to handle the VLAN11 traffic correctly. (It's also welcome if you can post the screenshot of how you configure your gateway interface and VLAN)
Besides, your SSID setting is correct, which means the AP correctly send the packets out with tagged 11.
Best Regards,
Richard0
Best Regards,
Richard0 -
Best Regards,
Richard0 -
Hi Richard,
thank you very much for carefully reading. I will test this again und search more intensive on the other site of the LAN cable.
After this i will give you a feedback.
Thank you again und best regards.
Sven
Hi Richard,
the IP 192.168.2.... is from out management network. In my tests today I used one firewall port for the management VLAN 1 and another firewall port for some other VLANs (11,12,13, ...). In this constellation all VLANs are working and the WLAN client gets the correct IP by DHCP over the Zyxel AP. I will do more tests in the next days with the firewall but i think its not the problem of the AP.
Many thanks for your help.
Sven
- 220 Nebula Ideas
- 607 USG FLEX H Series
- 482 News and Release
