I locked myself out
Yesterday I wanted to disable the remote access to the WebGUI from the internet.
However, I disabled Management Access with port 443 and locked myself out.
Therefore, I have no access to my ZyWall 110.
Unfortunately, SSH is not allowed and I know only 1 possible options to regain access:
- reset the ZyWall and restore a backup
Are there other possibilities? Can I enable SSH or Management Access (port 443) over the console port?
Hi @HaPeKa,
If you want to enable SSH please execute this command over the RS-232 console terminal:Router(config)# ip ssh server
If you want to enable HTTP and HTTPS servers please execute these commands over the RS-232 console terminal:Router(config)# ip http secure-server
Router(config)# ip http server
How did you disable the remote access to the WebGUI from the internet?
If you disabled port 443 in Policy Control Rule from WAN to ZyWALL, then you can try this command to disable Firewall function:Router(config)# no firewall activate0
Hi @HaPeKa,
If you disabled port 443 in Policy Control Rule from WAN to ZyWALL, then you can try this command to disable Firewall function:Router(config)# no firewall activate0 -
Thank you, I'll reconfigure http secure-server as you advised!
hmm, my usual login does not work on the console port.
and I'm shure about my username / password, I used it regularly.
I guess, there's no other way than reset the ZyWall 1100 -
after a restart I could login without any issues.
with the commands above I get an error:Router> configure% (after 'configure'): Parse errorretval = -1ERROR: Parse error/command not found!Router> ip http secure-server% (after 'ip'): Parse errorretval = -1ERROR: Parse error/command not found!Router> ip http secure-server% (after 'ip'): Parse errorretval = -1ERROR: Parse error/command not found!
I go and read the manual to find out, how to set the ZyWall in config mode0 -
Okay, problem solved ... first config terminal, then ip http secure-server and I can access the system on the GUI again.
Thanks for your help!
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
