NWA1123-ACv2 How to schedule turn off wifi?
I would like to schedule the wifi to be turned off at night to prevent it from sending radio emission, and also to save some power a bit.
I can do this using Fritz!Box. But, I haven't found an option to do this on NWA1123-ACv2.
I'm thinking of going back to Fritz!box if this is not possible with this Zyxel device.
@gainbore
Welcome to Zyxel Forum. The good new is, NWA1123-ACv2 supports the function you asked for, which is called "Schedule SSID". It allows users to configure the time/period where wireless services/radio to be propagated out.
If your SSID is in standalone mode, the setting page is under directory: Configuration > Object > AP Profile > SSID , Just select your using SSID and then click "Edit", then you'll see "Schedule SSID" in the bottom of pop-up window.
If your NWA1123-ACv2 is in cloud mode (managed by NCC), the setting page is under directory: AccessPoint > Configure > SSID Availability. Just simply select your SSID, and then enable the feature below, so you can set the schedule for your AP.
Best Regards,
Richard0 -
Hello
If is there only one SSID, ist the radio turned off too or still active?
Best Regards
Markus0 -
- 245 Nebula Ideas
- 6.9K Security
- 813 USG FLEX H Series
- 393 Security Ideas
- Threat Watch!
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 543 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 125 Security Highlight
