Unable to obtain authentication with WAC6103D-I RADIUS
@WanjuYang
Looks the profile setting on your AP is correct for 802.1X (just like your previous success cases) , so please help us to check the information below:
1. The server information set on the profile is correct (IP/Port/Secret)
2. Please make sure AP can access the External Server (you can use the ping from server to AP's IP address, and see if it's success)
3. Please make sure the AP is added into your RADIUS server's trust client list
If all above test are correct, but the issue still exists, I think we can further check the authentication process on the server side, and see in which step the authentication process interrupted. (Probably through the packet capture)
Looking forward to your update, and welcome to send me the files through private message if you have any concern.
Best Regards,
Richard1
@WanjuYang
Best Regards,
Richard1 -
Hi Richard
Thanks for your reply. After check ping from RADIUS to AP, I found there is access deny from vlan15 to vlan24. I config other WAC6103d-i which's vlan is access allow , it work normally.
Thank you very much.
Best Regards,
Wanju0
- 237 Nebula Ideas
- 6.8K Security
- 746 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
