USG40 Geo IP Not Working
enpingado
enpingado Posts: 3 image  Freshman Member
Third Anniversary
my USG-40 does not appear to be blocking based on Geo IP.
i have FW 4.65(AA 1), Geo IP date is 8-17-21
i create object for russia, used the geography setting.
then made policy as 1st rule to Deny, From Any, To Any Source-russia, Log
And i dont see anything in the log blocking traffic.
But i see the Default Rule Denying Russia labeled IPs in the log.
Why is my rule not blocking it?
Do i need to reboot after making new rules?
Best Answers
  • gb5102
    gb5102 Posts: 25 image  Freshman Member
    edited August 2021 Answer ✓
    Add a 2nd rule below the first one you created:
    To: ZyWALL
    Source: russia
    Action: Deny/log
    Reboot is not required for new rules to take effect.
    You need both.
    From any to ZyWALL only blocks to the USG like remote login (if you have a rule to allow that) and VPN.
    From any to any (except ZyWall) blocks like a NAT rule to a server for WAN to LAN and LAN to WAN
  • gb5102
    To: ZyWALL
    Source: russia
    Action: Deny/log
  • enpingado
    Third Anniversary
    great that worked perfect. So are two rules neccesary or just one?
    I see some suspect IP scanning different ports on my public static IP.
    Do i only need to block using rules with To=ZyWALL or both ZyWALL and other rule for Any(except ZyWall)?
    You need both.
  • enpingado
    Third Anniversary
    great thanks!
