USG40 Geo IP Not Working
my USG-40 does not appear to be blocking based on Geo IP.
i have FW 4.65(AA 1), Geo IP date is 8-17-21
i create object for russia, used the geography setting.
then made policy as 1st rule to Deny, From Any, To Any Source-russia, Log
And i dont see anything in the log blocking traffic.
But i see the Default Rule Denying Russia labeled IPs in the log.
Why is my rule not blocking it?
Do i need to reboot after making new rules?
Best Answers
Add a 2nd rule below the first one you created:From: AnyTo: ZyWALLSource: russiaAction: Deny/logReboot is not required for new rules to take effect.
You need both.
From any to ZyWALL only blocks to the USG like remote login (if you have a rule to allow that) and VPN.
From any to any (except ZyWall) blocks like a NAT rule to a server for WAN to LAN and LAN to WAN
great that worked perfect. So are two rules neccesary or just one?
I see some suspect IP scanning different ports on my public static IP.
Do i only need to block using rules with To=ZyWALL or both ZyWALL and other rule for Any(except ZyWall)?
You need both.
great thanks!0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
