ZON utility - Switches in different subnets
SeeSafe
SeeSafe Posts: 3 image  Freshman Member
edited August 2022 in Switch
Hi there.
I have a 54 switches in different subnets (192.168.0.1/16).
It would help me a lot if I could do a batch update and config.
Can I load a csv file in the ZON utility to manual add them?
Best regards
Soeren
  • Zyxel_Jonas
    Zyxel_Jonas Posts: 313 image  Zyxel Employee
    25 Answers First Comment Friend Collector Fifth Anniversary
    Hi @Soeren,
    Welcome to Zyxel Community!  :)
    May I know if you are encountering some problems while scanning the devices?
    I've tried it using ZON version 2.1.5, you should be able to scan all 54x devices within the subnet of 192.168.0.1/16, range IP that can be used will be 192.168.0.1 - 192.168.255.254.
    Just would like to inform that you may only upload the .bin file to upgrade the FW of the same device at the same time.
    Jonas,
  • SeeSafe
    Hi Jonas.
    Where do you input the segment you want to search for?
    In settings I only have the option to change the network adaptor.
  • Zyxel_Jonas
    Hi @SeeSafe,
    Yes indeed, the setting page only has those options. The network adapter is to choose which NIC you were currently using. (i.e. wireless)
    Sorry, could you define the "segment" you've mentioned? Or describe the goal you would like to achieve.
    Reminder: List of ZON utility features as the figure below. (Attached for the release note)
    And almost all of the features could be found in the upper center of the application.
    Jonas,
  • SeeSafe
    My computer has ip 192.168.10.68/16 and all my switches has ip:
    192.168.12.30
    192.168.13.30
    192.168.14.30
    etc.
    192.168.82.30
    and those I want to upgrade in a batch.
    Best regards
    Soeren
  • Zyxel_Jonas
    edited September 2021
    Hi @SeeSafe,
    Got it.
    Step as follows:
    1) choose the correct network card on the setting page.
    2) Click on the "Clear and rescan" button. You should be able to see a list of devices.
    3) Checkbox the devices which you would like to upgrade.
    4) Click on "Firmware Upgrade" button.
    5) Browse the file where you've downloaded the FW file, and then input the device password. Click on "OK" button to process.
    Note: Online upgrade is also an option if you haven't had the FW file.
    Hope it helps.
    Jonas,
