Subnet bug I think
USG60W V4.65(AAKZ.1)
I made a VLAN4091 on base port LAN1
192.168.254.9
255.255.255.248
DHCP 192.168.254.10 pool size 5
Other subnets
LAN1 192.168.254.129 / 255.255.255.128
WAN2 192.168.254.2 / 255.255.255.252
When make a device with IP of 192.168.254.10 it fails to have internet but 192.168.254.11 is fine
I have a subnet calculate that shows I'm subneting correctly?
Hi @PeterUK,By following your interface setting in lab device, Host 192.168.254.10 can get Internet access.Can you see host 192.168.254.10 packets send out to wan2 interface in routing trace if you ping to 8.8.8.8?
Go to MAINTENANCE > Diagnostics > Routing Traces and set 192.168.254.10 to source0
Go to MAINTENANCE > Diagnostics > Routing Traces and set 192.168.254.10 to source0 -
So this was odd as I did the Routing Traces for 192.168.254.10 to 8.8.8.8 with 60 second capture when pinging the whole USG rebooted! And when it was back on line 192.168.254.10 can now ping the internet.
I have done a debug info collector ask if you need it.
….But I think I know why the problem happened but can't think how it caused a problem. I needed for the client to NTP from VLAN4091 to 192.168.254.9 NAT to 192.168.255.250 then SNAT from 192.168.255.240 I made the mistake of putting in the NAT rule for external IP as 192.168.254.10 not 192.168.254.9.
All seems to be working now
- 435 Beta Program
- 176 Nebula Ideas
- 119 Nebula Status and Incidents
- 430 USG FLEX H Series
- 299 Security Ideas
- 79 Switch Ideas
- 276 Service & License
- 427 News and Release
- 89 Security Highlight
