NWA210AX - Homekit/mDNS/Bonjour issues
Hi @kevleviathan,
AP is a forwarding in this scenario, it will pass the traffic when AP receive the query from device.
Can you describe about the details of the symptom that all HomeKit devices which connect directly via Wi-Fi stopped responding?
Does it mean to the devices can’t access internet, or the communication between devices is dropped?
Thank you
Regards,
Bella
Zyxel_Bella said:
Hi @kevleviathan,
Thank you
Regards,
Bella
Sorry I should have specified - it means the devices appear in the Home app as “not responding” which as far as I understand means mDNS is not working for those devices. So essentially a problem communicating between devices. However they do connect to the AP and the router, and they have IP addresses, and they can reach the internet. It’s just the Apple Home app which shows them as “not responding”.But from your description it sounds like my assumption should’ve been correct that when operating as an AP, this device should not have any effect on mDNS as the router should ultimately be handling it?0 -
Noted. We can know the symptom from your description now.
Yes, if the devices are listed on Home App and can access internet without that means the AP passes the traffic properly.
We suggest upgrading driver of devices and App also the NWA210AX to latest firmware V6.20.
Thank you
Regards,
Bella
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
