About alpha1.rpc.cubs.zyxel.com
VPN50 V5.02(ABHL.0)
My VPN50 router performs a DNS resolving of alpha1.rpc.cubs.zyxel.com.mydomain.com. It is strange. Because this resolve is failed, it tries to find the following addresses:
_.com.mydomain.com
_.zyxel.com.mydomain.com
_.cubs.zyxel.com.mydomain.com
_.rpc.cubs.zyxel.com.mydomain.com
This situation is happened when:
System Name: mySubdomain.mydomain.com
Domain Name: <empty>
I cannot setup Domain Name, because several problems with e-mail from VPN50 will be (like Email Daily Report).
Is it possible to fix a suffix usage like mydomain.com for alpha1.rpc.cubs.zyxel.com ?
@xbolsheRegarding to your description,in my understanding, the "alpha1.rpc.cubs.zyxel.com " was created on the PTR record, and
mydomain.com created on domain name.
However, the FQDN"alpha1.rpc.cubs.zyxel.com.mydomain.com" cannot be resolved?Also, I just curious that related with issue of domain name, what exactly issue of Email daily report did you face?As my case,
couple settings combined could achieve, for example, if hostname is test.mydomain.comConfigure domain name of USGOn System -> Host Name, key in a domain name.(not fill in the system name)USG DHCP service will offer the Domain Name as DNS suffix for clientsAdd hostname into DNSThen the FQDN: test.mydomain.com can be resolved.0 -
As I understand, VPN50 uses alpha1.rpc.cubs.zyxel.com for some internal processes (a logic of Zyxel VPN50's developers). I do not use DNS records with *.zyxel.com. And it is strange to add my domain name to this address. Of course FQDN "alpha1.rpc.cubs.zyxel.com.mydomain.com" cannot be resolved, because it does not exist definitely.
Regarding to this issue, we will address this symptom, and just confirm with you that was this device managed by Orchestrator(SD-Wan)?
Otherwise, can you share more information what exactly issue did you face? And for investigating further, (If device managed by Orchestrator) please help to add both account access into this site.
- cso_security@zyxel.com.tw
- sdwan-its@zyxel.com.tw
No, I do not use SD-WAN. It is just a stand-alone VPN50 device. I found the problem looking into DNS traffic that goes from VPN50's WAN interface (there is no such traffic on LAN interfaces) to DNS server, where mydomain.com is hosted. "mydomain.com" is just hided my domain name. I have found that there are DNS requests with "alpha1.rpc.cubs.zyxel.com.mydomain.com" domain name from VPN50 as well as like "_.rpc.cubs.zyxel.com.mydomain.com".
@xbolshe
From my lab, VPN device is truly doing the DNS query to FQDN: alpha1.rpc.cubs.zyxel.com.
We will check it.
However, following the setting you mentioned " configure System Name: zyxel.cso.com", then packet capture on wan interface.
From my lab, the packet only appear alpha1.rpc.cubs.zyxel.com without zyxel.cso.com.
Therefore, can you private message the configuration to me for fully test?0
- 397 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.1K Security
- 87 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 916 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 211 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 913 Nebula FAQ
- 421 Security FAQ
- 237 Switch FAQ
- 207 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 139 Service & License FAQ
- 72 About Community
- 62 Security Highlight
