Last Firmware upgrade available
diego_cianet
Hello. I know it is an old device, but still works and I plan to build a small network with it. Where can I find the last firmware upgrade available for the switch model MES-3528?
Here is the output of the "MES-3528# show system-information"
Product Model : MES-3528
System Name : MES-3528
System Contact :
System Location :
System up Time : 0:02:28 (3ab7 ticks)
Ethernet Address : cc:5d:4e:3c:XX:XX
Bootbase Version : V1.05 | 02/19/2009
ZyNOS F/W Version : V3.90(BHR.5)20130312 | 03/12/2013
RomRasSize : 2404122
Thank you for your fast response. Do you recommend upgrade with both files, BHR.4 and then BHR.5?
Or should I upgrade only with the last one (BHR.5) ? Thanks again
I would think the BHR.51
Despite clicking the link and putting my username in, I can't seem to connect to the FTP. Can I just double check, im running V3.90(BHR.5) | 06/10/2011 on my MES-3528. Is this the latest version according to the FTP files?
I used third party App as FTP client (not anymore included into some browser) and i found files... Without username/passoword
- 234 Nebula Ideas
- 6.7K Security
- 706 USG FLEX H Series
- 369 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 313 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.2K FAQ
- 89 About Community
- 116 Security Highlight
