uplink currently operates at a lower speed 100 Mbps
Khyronn
Khyronn Posts: 3
edited May 2024 in Wireless
Hello all,
Sorry if my questions are stupid but i am a novice.
I just bought 2 NWA210AX and installed them in my home in order to have a good wifi signal on ground floor and first floor.
My 2 devices are directly connected to an ethernet cable with POE.
I activated the AP smart mesh.
On the access point board, one of my device indicates an alert status : uplink ocurrently operates at a lower speed 100 Mbps.
Could you help me to solve that problem.
Thanks a lot
Best Answers
    PeterUK Posts: 3,892  Guru Member
    What model is the POE? switch/injector?
    Can you test the unit next to the POE and another cable.
  • Zyxel_Silvia
    Zyxel_Silvia Posts: 77  Zyxel Employee
    5 Answers Friend Collector
    Hi @Khyronn ,
    Thank you for raising a question.
    The uplink shows 100Mbps is the result of automatic negotiation and 15m won't be a problem.
    As Peter mentioned, you may  try to change the new cables (CAT 5/5E) and connect to the different port of switch.
    These simple test can help us verify the problem.
    Best Regards,
    Silvia
  • Khyronn
    Khyronn Posts: 3
    Hi all,
    i just tested the access point with a direct rj45 cable of 15 m (cat 5e) and it works (on all switch ports). So, you're right, i have to check the rj45 in wall (i hope it is just a problem of rj45 socket and i won't have to replace the cable...).
    Thanks a lot for your help !
  • Hello, Thanks for your help.
    The switch is a little POE MOKERLINK G083MS (http://www.mokerlink.com/index.php?route=product/product&product_id=377), it is used both for the video surveillance system and to provide power to the two access points.
    I already tested a direct connection to the switch (the one in trouble) and it works with a 0.5 meters RJ45 cable (the twxo access points become green)...
    First, i thought  the distance was too far ( the two access points are at 15 m from the switch) but one of them works perfectly.
    So bad news is must be the cable one of the twisted pairs has a defect your going to have to pull a new cable run.
  • Zyxel_Silvia
    Hi @Khyronn ,
    Best Regards,
    Silvia
  • Khyronn
    Khyronn Posts: 3
    Hi all,
  • Zyxel_Silvia
    Hi @Khyronn,
    We’re so glad that your problem is resolved.
    Wish you have a nice day.
    Silvia
