Just bought a ZYXEL ATP100 upgrading from USG 50 - Configure question
Upgrading from a USG 50 to a new ATP100. I see somewhere there is a config converter or is that not able to be used for this one. Any suggestions or does it have to be manually done? I have a three VPN location set up so it isn't easy. Hope this ATP100 is easier to work with. Thank you..
Hi @Ft_Worth
You can refer to our "automated configuration migration tool". Since USG50 and ATP series has 2 generations difference, you'll need to convert the settings in this path: USG50 --> USG60-->ATP100.
However, it is still recommended to configure your ATP100 from beginning since the converted setting may have some differences due to HW/FW version/configuration structure changing.0
Hi @Ft_Worth
However, it is still recommended to configure your ATP100 from beginning since the converted setting may have some differences due to HW/FW version/configuration structure changing.0 -
ERxcellent answer!! I did not know that and this helps me and hopefully others.0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
