DHCP Larger the 256
                    CRU_Technologies
                                  in Security
            HI,
I have had a quick look but can't see an answer.
On a USG300 is it possible to have a DHCP range larger than 256 addresses?
Simon.
            Yes just change the subnet0
            That simple ey? Would of been beneficial if the error on the USG was a bit more informative than 'Computer Says No'.Thanks though.Simon.0
            you can use this to help where Host Address Range will be and on the DHCP increase the pool size
Online IP Subnet Calculator (subnet-calculator.com)
            @CRU_Technologies AFAIK someone is managing a firewall should be aware about the 254 hosts limit of .C Class networks (subnet mask 24bits/255.255.255.0).
I used 23 Bits mask (255.255.254.0) for allowing more than 300 customer devices into an hotspot network.0
 - 439 Beta Program
 - 2.8K Nebula
 - 200 Nebula Ideas
 - 6.3K Security
 - 499 USG FLEX H Series
 - 323 Security Ideas
 - 49 Wireless Ideas
 - 287 Service & License
 - 457 News and Release
 - 89 Security Advisories
 - 4.3K FAQ
 - 96 Security Highlight
