DHCP Larger the 256
CRU_Technologies
CRU_Technologies Posts: 24  Freshman Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Switch
HI,
I have had a quick look but can't see an answer.
On a USG300 is it possible to have a DHCP range larger than 256 addresses?
Simon.
    PeterUK Posts: 4,050  Guru Member
    Yes just change the subnet
  • CRU_Technologies
    That simple ey? Would of been beneficial if the error on the USG was a bit more informative than 'Computer Says No'.
    Thanks though.
    Simon.
    you can use this to help where Host Address Range will be and on the DHCP increase the pool size
    Online IP Subnet Calculator (subnet-calculator.com)
  • mMontana
    mMontana Posts: 1,434  Guru Member
    edited September 2021
    @CRU_Technologies AFAIK someone is managing a firewall should be aware about the 254 hosts limit of .C Class networks (subnet mask 24bits/255.255.255.0).
    I used 23 Bits mask (255.255.254.0) for allowing more than 300 customer devices into an hotspot network.
