Zywall-usg-20w firmware upgrade path
Before jumping into this and performing the firmwareupgrade I would like to ask what the upgrade path is for a Zywall USG 20W that is currently running Boot Module: 1.18 and Current Version: 3.30(BDR.9).
When trying to download firmware for the device I get presented with 465ABAR1C0.bin / C(ABAR.1)4.650
Can I simply jump to the latest or is there a path I need to follow?
Unfortunately no: USG20W don't support Firmware 4.x.
You should have USG20W-VPN for using 4.x firmware.
In any case.. you can download the latest WK48 lab firmware for latest fixes.
https://community.zyxel.com/en/discussion/4247/zywall-usg-series-v3-30p9-wk48-firmware-released
Thanks for your reply. So, I can jump directly to "USG 20W 3.30 BDR"? ....or am I already running it....inside the zip the file is named: "330BDR9ITS-WK48-r74988.bin"0
My current USG20W has been updated from BDR9 to BDR9 WK48 without any problem.It won't hurt to have a backup of the configuration before upgrade.0
Hi @h3ctic
You can update the firmware to v3.30P9 (WK48) directly.
Before upgrading the firmware, please remember to backup your config file.
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
