USG60W: lan1 not available in bridge available Interface
Is LAN1 part of the AP setup?
It was, for both SSIDs, now not anymore.But the vLANs for SSIDs disappeared from the available members.
Goal: use vLAN 99 as "bridge" to LAN1.use vLAN 96 as guest vLAN.Both not showing on the bridge page.Both used on SSIDs of the Wireless management. As Local Bridge. That's the "locking" setup?0 -
You likely don't need a bridge so like for VLAN 96 as guest you set in SSID forwarding mode loacl bridge and VLAN ID 96 with VLAN support on
IMVHO i should... i mean...Internal USG60W AP and a NWA5123-AC should share the same set of SSIds.
The "internal" SSID should lay on LAN1/lan1 (segment, network) as bridged.The "guest" SSID should be considered guest. But feed via the same cable to NWA5123-AC.In my mind i was feeding both vLANS on the LAN port, but the firewall should "connect" vLAN99 on lan1...Thanking you for your time and experience, i'm also open to suggestions.1 -
I have a USG60W and WAX510D and can get the guest SSID on both without a bridge you just setup VLAN with zone name In my case for guest base port LAN1 zone VLAN4902 192.168.250.1 255.255.254.0
SSID forwarding mode local bridge and VLAN ID 4902 with VLAN support on then set for each USG60W and WAX510D Group setting with that guest SSID
routeing from VLAN zone to WAN1 and Policy Control rule
Have you added NWA5123-AC to be managed by USG60W?
if you need more ports by LAN1 use port role1
- 221 Nebula Ideas
- 609 USG FLEX H Series
- 53 Wireless Ideas
- 299 Service & License
- 483 News and Release
