Remotely configure several USG devices
Hello!
I have about fifty Zyxel USG devices which configuration must be updated. It is hard to manually logging in each device to do the same thing, so i want to pass script with instructions over SSH. Is there some way to import ssh key to USG devices so i don't have to type password every time script connects to USG?
lalaland said:It's unable to import ssh key into USG. You can use python netmiko module to do something automatically for network device configuration.
https://ktbyers.github.io/netmiko/#tutorialsexamplesgetting-startedSad to know it.Well, already did it with netmiko using cisco_ios device_type. Here what its like, hope it helps anyone1
https://ktbyers.github.io/netmiko/#tutorialsexamplesgetting-startedSad to know it.Well, already did it with netmiko using cisco_ios device_type. Here what its like, hope it helps anyone1 -
Hi @arukashi,
Maybe Nebula solution can meet your requirement if you just want to configuration UTM service related for all sites. We have Security sync profile to apply UTM to all devices from Organization-wide.
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
