Problem to configure client VPN to VPN100
Hello
i have problem to set a vpn from external notebook to our lan by VPN100.
I have read this https://support.zyxel.eu/hc/it/articles/360001378833-Configurazione-da-client-VPN-a-sito-su-dispositivi-USG-ZyWall
And make as it tell but i see this error in log connection
Default (SA Ikev1Gateway-Ikev1Tunnel-P2) is opening.
Default (SA Ikev1Gateway-P1) SEND phase 1 Main Mode [SA] [VID] [VID] [VID] [VID] [VID] [VID]
Default (SA <unknown>) RECV Informational [NOTIFY] with NO_PROPOSAL_CHOSEN error
what's wrong?Thanks
Gio999 said:Thanks for your help. There are some guides o manual about this? Thanks
https://community.zyxel.com/en/discussion/comment/32987#Comment_32987
Something wrong on one of the sides of the VPN... "NO_PROPOSAL_CHOSEN" means that into phase 1 there's no match between allowed cyphers on the firewall and allowed cyphers on the client.
Phase 1 -> check the gateway section into firewall than the phase 1 into the client.
Be sure to have Policy Control rule like from IPSec_VPN to ZyWALL as that one catches me out.1
Hello thanks for your help. I have resolved it. But i have a question. I have 2 office in VPN (same zyxel model vpn100) and i have set one of this to connect the notebook from home. Now the notebook see the lan and pc where i have maked the vpn, but not see the other office. There are possible that see the 2 office?
Thanks0 -
Building the correct routes and firewall rules for the segment of IPSec0
The user manual and a skilled-enough network competency on topology design.
Which was the issue of the creation of the VPN? Please, mark the correct post/solution, or feel free to explain what was wrong.
Maybe could help the next person like you that's having the same problem0 -
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
