ZyWall IpSec VPN client crashes when searhing certificates
ismo
ismo Posts: 1 image  Freshman Member
I Try to use Ipsec/IKEv2 with client authentication using a x509 certificate. I have installed signing CA and client certificates to windows cert store (local computer), but when I try to select Certificate-tab in Ikev2Gateway, the client crashes after telling that it is updating certificate list.
Client is:
vpnconf.exe 5.6.80.007
TgbIkeNG.exe 6.8.0.005
ComLib.dll 6.0.0.005
VpnToken.dll 4.0.0.005
TgbLogonUI.exe 5.6.80.007
SSLeay32.dll 1.1.1g
TgbStarter.exe 5.0.0.005
VpnDialer.exe
VpnCfg.dll 5.0.0.005
TgbLibeay32.dll 1.1.1g
TgbStarterLang.dll 2.0.0.005
TgbEvtLogs.dll 2.0.0.005
TgbCredProv.dll 5.6.80.007
TGBMPEnum.sys 3.01.02.0003
TGBVPNVirtM.sys 3.02.04.0003
And windows 20H2 (OS build 19042.1237)
Any ideas how to fix this?
  • Zyxel_Stanley
    edited September 2021
    Hi @ismo
    This situation may come from software interoperability with your windows.
    For further check this issue, you can collect your windows info and send .nfo file to me by private message.
    (Start -> Run -> msinfo32 -> File -> Save)
