Remotely configure several USG devices
Hello!
I have about fifty Zyxel USG devices which configuration must be updated. It is hard to manually logging in each device to do the same thing, so i want to pass script with instructions over SSH. Is there some way to import ssh key to USG devices so i don't have to type password every time script connects to USG?
lalaland said:It's unable to import ssh key into USG. You can use python netmiko module to do something automatically for network device configuration.
https://ktbyers.github.io/netmiko/#tutorialsexamplesgetting-startedSad to know it.Well, already did it with netmiko using cisco_ios device_type. Here what its like, hope it helps anyone1
https://ktbyers.github.io/netmiko/#tutorialsexamplesgetting-startedSad to know it.Well, already did it with netmiko using cisco_ios device_type. Here what its like, hope it helps anyone1 -
Hi @arukashi,
Thanks for sharing the python script. it helps a lot.0 -
Hi @arukashi,
Maybe Nebula solution can meet your requirement if you just want to configuration UTM service related for all sites. We have Security sync profile to apply UTM to all devices from Organization-wide.
- 397 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.1K Security
- 91 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 921 WirelessLAN
- 35 WLAN Ideas
- 5.9K Consumer Product
- 210 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 938 Nebula FAQ
- 425 Security FAQ
- 238 Switch FAQ
- 210 WirelessLAN FAQ
- 47 Consumer Product FAQ
- 139 Service & License FAQ
- 72 About Community
- 62 Security Highlight
