USG 20 REBOOTING ISSUE
LorenzoEllegi
in Security
I've been using my Zywall USG 20 since 2014 without any problem.
In the last few weeks, it keeps rebooting, randomly, every 15 minutes.
I tried to replace the power adapter, but the problem is still there.
I have also updated the firmware to the last release, but the USG 20 still has the same problem.
I'm now trying a USG100 that has the same pro
blem!!!
blem!!! Attached: MONITOR SCREENSHOT
Please help
USG20 is... out of support, since 2016. I am aware because I am using USG20W
Latest firmware version is 3.30 BDR9 WK48 (BDR is for USG20W but there's the equivalent version for USG20), some issues were solved into this latest "laboratory" firmware, which i don't know if it's available also for USG100.Anyway...I don't know what kind of power supply you're using, but i had some issues with not so performant switching power adapters. With 1.5 or 2.0A of sustained capacity (2.0 better for USG100) never had any issue.0 -
Hello @LorenzoEllegi
Just as @mMontana mentioned that the latest firmware version of USG20 and USG100 is v3.30P9 (WK48), you can download it via the below link:
https://community.zyxel.com/en/discussion/4247/zywall-usg-series-v3-30p9-wk48-firmware-released
Hope this can help you.0 -
Here is another forum discussion that is similar to yous, you can refer to it: https://community.zyxel.com/en/discussion/11601/zywall-usg-20-keeps-rebooting#latest0
- 588 USG FLEX H Series
- 477 News and Release
