Zywall 110 strange traffice statistics
From few months I observe strange traffics statistics.
My config
P1 - WAN (backup connection)
P2 - WAN (main connection)
P3 - OFF
P4 - LAN
P5 - OFF
P6 - OFF
P7 - OFF
What is strange? On P2 I see 17Mbps. In the same moment on LAN 0Mbps.
What generate traffic on WAN P2 port?
I changed the device: the problem persists. Now I use firmware V4.65(AAAA.0) but problem was on the older firmware too. I have this problem only with one of ten offices.
Pictures below.
other ports (OFF)
Hi @LeszekDo you enable UTM signature auto-update and SecuReporter on your Zywall110?Because those two features may generate traffic from WAN to the internet.
Thanks.0 -
Do you enable UTM signature auto-updateNo...SecuReporter on your Zywall110?No0
Hi @LeszekCould you provide your device config file to us via private message for further investigation?
Thanks.0 -
Hi Leszek, i have similar problem :but after any FW update problem gone ...
FW V4.65(AAAA.1) and statistics
problem solved
the cause on the supplier's side
- 3K Nebula
- 222 Nebula Ideas
- 618 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
