nwa210ax & PoE12-HP. PoE not working.
Cossen
Cossen Posts: 1 image  Freshman Member
edited May 2024 in Wireless
Hi, i recently bought an nwa210ax AP, and I wanted to power it over POE. So I bought a PoE12-HP. It is the suggested Poe-injector on Zyxels own productpage for the AP. But all I get when connecting them together is the AP flashing green/orange for a while and then turning itself completely off. I have tried several cables and reboots but nothing works. Anyone have any experience with this?
  • Greenlight
    Greenlight Posts: 57 image  Ally Member
    edited October 2021
    Could you please try to boot it up with power adapter?
    Besides, you can also try to press the reset button on the back panel of the AP.
    If you don't see AP LED blinking/on, this can't directly link to AP's power off. since the LED can be suppression and not shown(configured by previous user). You can reset the AP to disable this setting.
  • Zyxel_Bella
    Zyxel_Bella Posts: 588 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Switch 50 Answers
    Hi @Cossen
    The AP flashing in green and amber is stands for the stage of boot up.
    As Greenlight mentioned, the LED status can be configured as suppression.
    Please reset AP by push the button on the device, with default settings, the LED is on and AP will broadcast SSID “Zyxel-XXXX” which is the last four letters of MAC address.
    It is a way to monitor if the AP boots up and works properly.
    If above method no success, can you use adapter or swap the AP to other ports on switch for testing. Then use a PC connecting to same switch and establish ZON to scan device.
    https://www.zyxel.com/tw/zh/products_services/Zyxel-ONE-Network-Utility-ZON-Utility/
    We’d appreciate your feedback when you have done above steps.
    Thank you
    Regards,
    Bella
  • kreleinew
    kreleinew Posts: 1 image  Freshman Member
    Friend Collector
    edited October 2021
    Hi @Cossen
    It is a way to monitor if the AP boots up and works properly https://applinked.me/ .
    Thank you
    Regards,
    Bella
    Thank you very much for the solution. It solved the problem.
