What is IKE and what has someone done in my USG40W ?
[Deleted User]
Since opening a NAT Port Forward I am keeping a close eye on logs lately and everything seems ok but for this entry I discovered a few minutes ago:
What does that mean and what has it done to my device?
There is nothing additional configured on the device, no VPN, no accounts, no vlan, or anything else
IMVHO someone try to... connect via IPSec.0
...and suceeded, or not?Most other entries in my log shows BLOCKED when conn is blocked. This does not.And here is another entry:
It seems someone is trying to build vpn to your device. Try to add a new security policy rule to block the suspect source IP or Geo IP.New RuleFrom: WANTo: ZyWALLSource: suspect source IP or Geo IPService: anyAction: denyIf you're using ipsec vpn, you can also edit the default WAN_to_Device rule and allow authorized IP in "Source".Default WAN_to_ZyWALL ruleFrom: WANTo: ZyWALLSource: authorized IPService: Default_Allow_WAN_To_ZyWALLAction: allow0
Well, that is the thing, I have no VPN configured, nothing whatsoever.
- 588 USG FLEX H Series
- 477 News and Release
