Zyxel USG20W-VPN setup and PPPoE connection
2»
  • mlik
    mlik Posts: 26 image  Freshman Member
    edited October 2021
    The topic from the first post is back. Today there is no internet point. As you can see, the update did not help to solve the problem. Surely, if he permanently enters the WAN address, the internet will return.
    I connected to the router and the WAN interface at DHCP got the strange address 10.10.10.29. Changing the address to permanent - correct address with WAN_PPP solved the problem. The question is why is this happening.
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,368 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    Could you provide the config file to us via private message for a further check?
    Thanks.
