SSL VPN Problem
LCIT
LCIT Posts: 1  Freshman Member
edited April 2021 in Security
Hello I'm experiencing difficulties to connect to my SSL VPN (USG210).
SecuExtender.log:
[ 2020/09/29 17:31:04 ][SecuExtender Helper] ######## Build Datetime: Sep  5 2018/13:29:07 ########
[ 2020/09/29 17:31:04 ][SecuExtender Helper] osvi.dwPlatformId = 2, osvi.dwMajorVersion = 6, osvi.dwMinorVersion = 2
[ 2020/09/29 17:31:04 ][SecuExtender Helper] shared memory is create
[ 2020/09/29 17:31:04 ][SecuExtender Helper] Get a valid selfsigned certificate.
[ 2020/09/29 17:31:04 ][SecuExtender Helper] certificate fingerprint: ******
[ 2020/09/29 17:31:04 ][SecuExtender Helper] https server init success
[ 2020/09/29 17:31:58 ][SecuExtender Helper] Request(102): REMOVE 234989760/180461133 14 4294967295 4294967295
[ 2020/09/29 17:31:58 ][SecuExtender Helper] Remove Routing
[ 2020/09/29 17:31:58 ][SecuExtender Helper] Remove prioritize routing
[ 2020/09/29 17:31:58 ][SecuExtender Helper] Get netsh path = powershell
[ 2020/09/29 17:31:58 ][SecuExtender Helper] ia is null
[ 2020/09/29 17:31:58 ][SecuExtender Helper] Failed to read from client(2): 109, 0
[ 2020/09/29 17:31:58 ][SecuExtender Helper] Start to Disconnect pipe...
[ 2020/09/29 17:31:58 ][SecuExtender Helper] Shutting down a pipe connection instance...
[ 2020/09/29 17:31:58 ][SecuExtender Helper] ==============================</code>[ 2020/09/29 17:31:35 ][SecuExtender Agent][DETAIL]&nbsp; Build Datetime: Sep&nbsp; 5 2018/13:28:56<br>[ 2020/09/29 17:31:35 ][SecuExtender Agent][DEBUG]&nbsp;&nbsp; SecuExtender.log: C:\Users\******\SecuExtender.log<br>[ 2020/09/29 17:31:35 ][SecuExtender Agent][DEBUG]&nbsp;&nbsp; osvi.dwPlatformId = 2, osvi.dwMajorVersion = 6, osvi.dwMinorVersion = 2<br>[ 2020/09/29 17:31:35 ][SecuExtender Agent][DEBUG]&nbsp;&nbsp; interface guid: {FD33527B-80B5-4465-A357-F794156A1515}, idx: 10<br>[ 2020/09/29 17:31:35 ][SecuExtender Agent][DEBUG]&nbsp;&nbsp; tBuf : (\DEVICE\TCPIP_{FD33527B-80B5-4465-A357-F794156A1515})<br>[ 2020/09/29 17:31:35 ][SecuExtender Agent][DEBUG]&nbsp;&nbsp; network name got, idx: 11<br>[ 2020/09/29 17:31:57 ][SecuExtender Agent][DETAIL]&nbsp; Checking service (first) ...<br>[ 2020/09/29 17:31:57 ][SecuExtender Agent][DETAIL]&nbsp; SecuExtender Helper is running<br>[ 2020/09/29 17:31:57 ][SecuExtender Agent][DETAIL]&nbsp; Try to connect to SecuExtender Helper<br>[ 2020/09/29 17:31:57 ][SecuExtender Agent][DETAIL]&nbsp; SecuExtender Helper is connected<br>[ 2020/09/29 17:31:57 ][SecuExtender Agent][INFO]&nbsp;&nbsp;&nbsp; [******] try to login vpn.******.com:8443<br>[ 2020/09/29 17:31:57 ][SecuExtender Agent][INFO]&nbsp;&nbsp;&nbsp; Connect to ******<br>[ 2020/09/29 17:31:57 ][SecuExtender Agent][INFO]&nbsp;&nbsp;&nbsp; Local address is ******<br>[ 2020/09/29 17:31:57 ][SecuExtender Agent][DEBUG]&nbsp;&nbsp; Connect success.<br>[ 2020/09/29 17:31:57 ][SecuExtender Agent][DETAIL]&nbsp; Handshake LoopCounter: 0<br>[ 2020/09/29 17:31:57 ][SecuExtender Agent][DETAIL]&nbsp; 1200 bytes of handshake data received<br>[ 2020/09/29 17:31:57 ][SecuExtender Agent][DETAIL]&nbsp; InitializeSecurityContext returns 0x90312<br>[ 2020/09/29 17:31:57 ][SecuExtender Agent][DETAIL]&nbsp; Send 126 bytes of handshake data<br>[ 2020/09/29 17:31:57 ][SecuExtender Agent][DETAIL]&nbsp; Handshake LoopCounter: 1<br>[ 2020/09/29 17:31:57 ][SecuExtender Agent][DETAIL]&nbsp; 274 bytes of handshake data received<br>[ 2020/09/29 17:31:57 ][SecuExtender Agent][DETAIL]&nbsp; InitializeSecurityContext returns 0x0<br>[ 2020/09/29 17:31:57 ][SecuExtender Agent][DETAIL]&nbsp; SSL Handshake is successful<br>[ 2020/09/29 17:31:57 ][SecuExtender Agent][DETAIL]&nbsp; STREAM_SIZE: Header: 13&nbsp;&nbsp;&nbsp; Trailer: 16, MaxMessage: 16384<br>[ 2020/09/29 17:31:57 ][SecuExtender Agent][DETAIL]&nbsp; Protocol: TLS1.2<br>[ 2020/09/29 17:31:57 ][SecuExtender Agent][DETAIL]&nbsp; Cipher: AES256<br>[ 2020/09/29 17:31:57 ][SecuExtender Agent][DETAIL]&nbsp; Cipher strength: 256<br>[ 2020/09/29 17:31:57 ][SecuExtender Agent][DETAIL]&nbsp; Hash: SHA384<br>[ 2020/09/29 17:31:57 ][SecuExtender Agent][DETAIL]&nbsp; Hash strength: 0<br>[ 2020/09/29 17:31:57 ][SecuExtender Agent][DETAIL]&nbsp; Key exchange: 0xae06<br>[ 2020/09/29 17:31:57 ][SecuExtender Agent][DETAIL]&nbsp; Key exchange strength: 256<br>[ 2020/09/29 17:31:57 ][SecuExtender Agent][INFO]&nbsp;&nbsp;&nbsp; Server subject: CN=usg210_******<br>[ 2020/09/29 17:31:57 ][SecuExtender Agent][INFO]&nbsp;&nbsp;&nbsp; Server issuer: CN=usg210_******<br>[ 2020/09/29 17:31:57 ][SecuExtender Agent][ERROR]&nbsp;&nbsp; **** Error 0x800b0109 authenticating server credentials! (0x0)<br>[ 2020/09/29 17:31:58 ][SecuExtender Agent][DETAIL]&nbsp; SSL session is created<br>[ 2020/09/29 17:31:58 ][SecuExtender Agent][DETAIL]&nbsp; Can't get authentication token(1)<br>[ 2020/09/29 17:31:58 ][SecuExtender Agent][DEBUG]&nbsp;&nbsp; SSL Connection is going to be closed<br>[ 2020/09/29 17:31:58 ][SecuExtender Agent][ERROR]&nbsp;&nbsp; user login device failed (0x0)<br>[ 2020/09/29 17:31:58 ][SecuExtender Agent][DEBUG]&nbsp;&nbsp; SSL Connection is going to be closed<br>[ 2020/09/29 17:31:58 ][SecuExtender Agent][DETAIL]&nbsp; Connection ends.</pre><br><div>SecuExtenderHelper.log:</div><div><pre class="CodeBlock"><code>
(I replaced what I believe to be sensitive data with "******")
I tried everything (ports opening in firewall, disable windows defender, DISM and SFC repairs, reset network settings, test with another network card, internet box and computer resets, etc).
Whatever I try I keep getting these "Can't get authentication token(1)" and "ia is null" errors.
Any help appreciated thank you.
  • Hi
    I have same problem today, have you find the cause ?
    Thank you
  • Zyxel_Cooldia
    Zyxel_Cooldia Posts: 1,520  Zyxel Employee
    Hi @LCIT, and @bYAdmin
    Welcome to Zyxel Community. =)
    Is the SSL VPN connection issue only on specific client ? Assume it is general to all windows client.
    Please send  my your configuration file in PM for further checking.
